It is currently Thu Jun 11, 2026 2:50 am
 Post subject: changing water pump
PostPosted: Wed Nov 13, 2013 2:51 pm
hey guys changing the water pump on a new truck (hope thats really the issue)
said its full of coolent and fan is spinning, but its still overheating and there is a weird noise.
drain coolant, pull the radiator, remove the belts/pulleys, pull the water pump (loosening but not removing top bolt) and doing it all in reverse order.
anything tips/tricks/corks i should know about
never done this before... wish me luck!
 Post subject: Re: changing water pump
PostPosted: Wed Nov 13, 2013 3:08 pm
Water pumps tend to chatter (or clatter) when they go bad, but in my experience, they usually lose water and that's what makes them overheat. You may also have a plugged up radiator. They lose efficiency over time, as passages become blocked.
