It is currently Thu Jun 11, 2026 12:02 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: good deal?
PostPosted: Thu Oct 31, 2013 3:35 pm
guy wants 1k says it runs good "if i had to drive it to NYC tomorrow i would" (good sales pitch :P)
1979
anything i should look out for when i go check it out tomorrow?
thanks for helping me (newbieeee)
 Post subject: Re: good deal?
PostPosted: Thu Oct 31, 2013 6:55 pm
Looks pretty dang clean for 1000 bucks. Almost too good to be true, actually. Is the interior gone or something? From what he says, it runs well, but do you have any pics of the engine bay?
Is there any rust in the floorpans? Wheel wells? Frame??
Based on those 3 images you posted, I'd say it's worth a thousand dollar gamble
edit: feel free to sell me your rear bumper when you buy the truck.
PostPosted: Thu Oct 31, 2013 8:00 pm
no pics of the engine.. here are the only other 2 pics i got...
it come with an extra hood... and somthing else... if its the bumper ill hit you up!
PostPosted: Thu Oct 31, 2013 8:49 pm
The license tags say 2011 so hopefully the pictures are current. In California back due registration can kill a deal pretty quick. If it looks like that and runs it is a good deal. Lift up the carpet and check the floors though. 8)
PostPosted: Thu Oct 31, 2013 8:56 pm
Check the rocker panels under the door for rust.
PostPosted: Thu Oct 31, 2013 9:48 pm
it was his sons truck, who moved. im pretty sure the pics are current. i dont think there is any sort of back due registration fees here in Wash.
thanks for the tips guys! ill take some more pics when i get out there. i hope it all checks out, dont wanna have to take the greyhound home too :)
PostPosted: Thu Oct 31, 2013 9:51 pm
also any tips for cheap tonneau covers? maybe even DIY options?
THANKS!
PostPosted: Thu Oct 31, 2013 10:37 pm
If that truck was in Texas i would already own it for 1K
PostPosted: Thu Oct 31, 2013 10:39 pm
Same here...
PostPosted: Sat Nov 02, 2013 7:12 pm
so it was a 3 hour drive home... it was going well until all the sudden it started puttering out...(about 2 hours into my drive home) seemed like maybe fuel wasnt going through or something... i pulled over and sat for a few minutes then tried it again and she rode fine the rest of the way home...
when i tried to start her this morning she started up then puttered out when i tried giving her gas.... but after a couple goes stayed cookin.... and was fine the rest of the day... i put a new fuel filter in but the old one seemed like it was allowing air ok (blow test)
any ideas about whats happening?
seemed like it was also idleing a little fast too, so i adjusted the carb a bit... much better now.
also when i turn stop the engine she kind of shakes a bit for a split second?
as requested, some pics of the engine bay
THANKS GUYS!
PostPosted: Sat Nov 02, 2013 7:31 pm
Nice,My guess is the gas tank has some gunk in it, if it sat for any length of time. The filter was a good place to start, but there should one back by the tank if you didn't know. I would change it if you haven't. The sheet metal under the hood looks great, I think you scored with the truck. 8)
PostPosted: Sat Nov 02, 2013 7:37 pm
Nice,My guess is the gas tank has some gunk in it, if it sat for any length of time. The filter was a good place to start, but there should one back by the tank if you didn't know. I would change it if you haven't. I think you scored with the truck. 8)
thanks! i did look for the a 2nd filter but did not see it... maybe i missed it, ill check tomorrow.
was also thinking about dumping some heet water dryer and some sort of carb cleaner into the gas tank?
also found a extang tonneau cover that will fit on craigs for 50 bucks! decent cover?
PostPosted: Sat Nov 02, 2013 8:31 pm
Extagg covers are nice . $50 is another steal . You need to buy a lotto ticket man .
PostPosted: Sat Nov 02, 2013 10:19 pm
Nice find. Congrats.
PostPosted: Sun Nov 03, 2013 10:57 am
Looks like it has a Weber card on it. If so you are looking at $400 in savings already. It has been de smog'd, not much of a benefit there but it cleans up the engine bay. I am surprised the battery actually has a hold down, most LUV's in this price range don't have them. Looks to me that this truck was taken care of at some point in its life. You got a great deal for that price.
PostPosted: Sun Nov 03, 2013 12:13 pm
Well done, nice carb. You basically got a $600 vehicle, and a bonus weber carb -installed- for free 8) . It's probably the nicest upgrade for a stock truck.
A few fuel system hiccups are tolerable in the face of that kind of fortune. It seems to have been a well-cared-for truck.
When you figure out what is actually causing your few problems, do share. Threads like yours are very helpful to new members later on.
PostPosted: Sun Nov 03, 2013 4:02 pm
found the other filter down by the gas tank... replaced it (it was pretty bad) and dumped some sea foam into the tank.
kind of puttered a bit and wanted to die again this morning when i tried to start her, but less than yesterday and after a couple tries it was running well again... drove around town and she was fine (starts right up everytime)
my gal is into it!!!!
PostPosted: Sun Nov 03, 2013 5:40 pm
I think I see a problem with your truck. The Weber needs a fuel pressure regulator, I don't see one in your pictures. Here is one post about it
viewtopic.php?f=6&t=27845&p=203540&hilit=Weber+fuel+pressure#p203540
PostPosted: Sun Nov 03, 2013 5:56 pm
hmmmm i will check it out... hopefully its not harming my engine too much?
also im having a "Dieseling" issue.... do you think that might be the reason...
from what iv read on the site it may be a carb or timing issue... should i test one before the other?
thanks guys!!!
PostPosted: Sun Nov 03, 2013 7:23 pm
Get the fuel pressure regulator installed, with a weber you must have one to get down to the 2.5 psi you need. Then tune it as per the instructions in the info area, check and adjust the timing and the dieseling will most likely go away.
