It is currently Tue Apr 23, 2024 10:38 pm
PostPosted: Thu Sep 12, 2013 6:17 pm
I have a (new to me) 1979 4X4 LUV that I just adore.
The driver's side rear axle came off. I took it apart and found the lock washer tab that bends in to hold nut
had broken off and the nut is worn flat inside a section.
I cannot find these parts. Can someone please help me?!?
Thank you - Annie (from Cali) : )
PostPosted: Thu Sep 12, 2013 9:55 pm
Are you talking about the the retainer/washer for the large nut that holds the axel bearing on? If so it might be hard to find, you might need to buy a used axel to get one.
PostPosted: Fri Sep 13, 2013 11:29 am
Thank you! Yes, I have found it challenging to find the parts. Good option, though : )
I'll post it if/when I find parts.
PostPosted: Fri Sep 13, 2013 4:26 pm
I think your best bet is to see if ISUZU used them on their later trucks, if so they might still be able to get them.
PostPosted: Fri Sep 13, 2013 6:03 pm
That's a great idea!! Thank you! It will be my weekend hunt : )
Annie
PostPosted: Fri Sep 13, 2013 6:13 pm
Here is the Chevrolet part numbers
Washer. 94020202
Nut. 94020187
PostPosted: Fri Sep 13, 2013 6:47 pm
I think those parts are likely to be the same in Isuzu pickups and Troopers up to 1986. After that it gets iffy. 1981-1986 I'm not even certain of but they should be same as the axles didn't change much.
PostPosted: Sat Sep 14, 2013 1:18 am
You can find those nuts and bolts at any nut and bolts place and washers and then u juss chase the threads if not at the junkyard u will find one izusu fits up to 86 i knlw ive used parts from one for my truck
PostPosted: Mon Sep 16, 2013 3:05 pm
Thank you everyone for all the helpful directions!! You guys are awesome! Annie : ) :P
PostPosted: Thu Jan 23, 2014 12:50 pm
I'll check my parts bin and let you know if I have anything :)
