It is currently Wed Jun 10, 2026 5:18 am
PostPosted: Wed Sep 04, 2013 5:38 pm
I have an '80 LUV and was wondering what grease I should put in my steering gear box. I noticed a square fill plug on the top and was wondering if maybe a gear oil or something was supposed to be in it. It is very hard to steer so I am guessing it has nothing in it. If anyone has the answer please let me know. Thank you all. JOSH
PostPosted: Wed Sep 04, 2013 9:52 pm
FSM says 90w gear oil, so use whatever you would use in your differential.
PostPosted: Wed Sep 04, 2013 9:54 pm
The problem is where did the oil go? It does not evaporate, therefore I would think it leaked out.
PostPosted: Thu Sep 05, 2013 8:07 pm
I don't see anywhere where it could have leaked but that's a good possibility. The guy I bought it from let it sit for 5 years. I have replaced almost everything on the truck and engine. I'm in the process of lifting it. Does anyone have ideas on lifting? The only thing I can think of is a body lift, because I don't wanna switch the front end out with a Toyota.
