It is currently Wed Jun 10, 2026 3:10 am
 Post subject: 1981 LUV Radio
PostPosted: Wed Aug 28, 2013 5:55 pm
I have three old stock radios and all the parts to get one installed in my 1981 LUV. The problem is that I can't get any one of them to work. The wire seems to be hot - it sparks when you cross hot with neutral - but I can't get any response. It seems unlikely that all three are defective....is there any trick to getting a LUV radio to work?
Any thoughts appreciated.
Thanks,
PJ
 Post subject: Re: 1981 LUV Radio
PostPosted: Wed Aug 28, 2013 9:09 pm
No. The "hot" wire should be switched, not constant.
I don't remember if the factory radio had illumination that was wired into the instrument lighting, or if it lit up when turned on...but is it possible you're connecting power to the lighting connection?
PostPosted: Fri Aug 30, 2013 10:01 pm
I've got the radio working.....the only problem now is I can't get any reception. Is this a common problem on these old LUVs? Would it be worth considering an aftermarket antenna? Any thoughts appreciated. Thanks, PJ
