It is currently Wed May 27, 2026 4:28 am
 Post subject: HOT coil...
PostPosted: Sat Jul 27, 2013 7:02 pm
Been having issues with my 1979... on cold startup it runs fine.. once warm it idles great but you give it a liitle gas just above idle it sputters. The coil (just replaced to a new internal resistor) is very hot and the ignition and light switches seem to be warm... just took apart the carb and replaced it, i noticed the old ballast resistor was super hot while it was running... what could be the problem? Help.... thanks :egeek
... Good, you've located the problem; step 2 is washing it off.
