It is currently Tue May 26, 2026 10:56 pm
PostPosted: Tue Jul 16, 2013 9:15 am
I think the fuel pump regulator is out on dad's 1978 Luv. Are new regulators still available or shall I just bypass with hotwire? Thanks for any help.
PostPosted: Tue Jul 16, 2013 7:04 pm
There were not fuel pump regulators on LUVs.
PostPosted: Tue Jul 16, 2013 7:21 pm
The relay can die, it is under the cover on the passenger side fender. The other thing that can cause problems with the fuel pump is the alternator or voltage regulator though. The pump is designed to only run when cranking the starter or when the motor is spinning.
I don't recommend bypassing the fuel pump relay without at least some safety cut off, it could be the only thing that keeps from causing a massive fire in a crash. Somewhere around here a while back someone figured out how to wire a bosch type relay into the harness in place of the fuel pump relay.
If the truck fires for a while when starting then cuts out when the key is turned back from start to run also check the ballast resistor on the coil.
