So I noticed when I had my wheels off to paint, that I have a small leak from the rear end. Couple questions about this. It is leaking out where the driveshaft goes in, so what part would I need to replace to keep this from leaking? Second, which one is the fill hole?
I see the one on the back facing the camera, but it isn't even halfway up..is that all the fluid it holds? Or is it that little tube on the top slightly off to the right side? Really for now the leak is small enough I can live with it, just want to make sure the rear end doesn't run dry.
and last, what do you guys run for gear oil in these? I'm sure there is a lot I can use, just seeing if anyone has preferences?
thanks!
