It is currently Thu Jun 11, 2026 9:19 am
 Post subject: Engine questions 1.8L
PostPosted: Mon Sep 10, 2012 11:47 am
81 chevy luv - engine is from a 79 1.8L gas
I spent this weekend trying to find an exhaust leak #4cyl exhaust manifold gasket had failed so I replaced that. Previous owner removed all the emissions equipment there is a tube above the exhaust manifold with small tubes that attach to the head just above the manifold, I believe this is part of the EGR system, can I remove this tube and install plugs where it attaches to the head? I believe this tube is the source of my leak. My second question is do the head gaskets commonly fail on these engines? I am getting a misfire and my cooling system has lots of pressure even after sitting 8+ hours and the coolant smells slightly of gas/exhaust.
1971 Chevrolet K20 4x4 350/350/NP205
1981 Chevrolet Luv 4x4 1.8L/4SP
PostPosted: Mon Sep 10, 2012 3:12 pm
yes you can remove the rail above manifold and plug holes and on the head gasket mine blew twice in less than a year
if it aint a luv it aint shit
PostPosted: Mon Sep 10, 2012 5:28 pm
i took the air rail out and plugged it with 14mmx1.25 threaded plugs i made from 14mm bar.
i have been driving on my head gasket for a bit over a year before i had my head rebuilt and the new one has been fine since then for almost another year now and i abuse the heck out of my motor it see's 4-5k rpm pretty much daily
PostPosted: Sat Sep 15, 2012 10:32 am
good information, never occurred to me to make my own plugs I was looking for plugs that would fit excellent idea. I was going to do a compression check this weekend but left my gauge at work. I hope the head gasket is not bad it seems to run ok even with the Rochester carb and has good power.
PostPosted: Sat Sep 15, 2012 2:42 pm
Pull the air rail, cut the individual tubes & remove from the threaded inserts, tap & plug (or weld) the inside of the inserts & reinstall the plugged inserts.
PostPosted: Mon Sep 17, 2012 8:20 pm
tapped and threaded the inserts for 3/8 fine thread and put some high temp thread locker and tightened them down. works perfectly, no more exhaust/compression leaks. excellent idea
