Langhauz wrote:
Hello all,
I recently had a rebuilt 1.8L put into my '79 4x4 (along with new clutch and flywheel)
The truck runs great except when it's shut off and cools down I lose about 2oz of coolant from the block/radiator region.
Those are two completely different areas. The radiator could be leaking, hoses, overflow hose and so forth. The block could have a bad head gasket, water pump, where the hoses connect to the pump and thermostat housing could be leaking...need to check where the leak is coming from before you start wrenching.
