It is currently Tue May 26, 2026 7:06 pm
 Post subject: Timing
PostPosted: Sat Feb 04, 2012 1:32 pm
My 1980 2wd luv is running at 0 degrees TDC with the vacuum line to the dizzy plugged........the hanes manual says 6 degrees TDC. The truck runs fine and seems to be getting good gas mileage (24mpg). Everything is original besides the tune-up items points, sparkplugs, cap rotor,etc. What should i do?
 Post subject: Re: Timing
PostPosted: Sat Feb 04, 2012 2:30 pm
How does it run at 6?
Is the power ok at 0?
I would think 6 would give you much more power. I would try 6 if it runs well there, you can always put it back to 0 if you want.
PostPosted: Sat Feb 04, 2012 5:09 pm
Try 3 degrees, if it runs cool and does not ping then push it up ro 6.
