It is currently Tue May 26, 2026 7:38 pm
PostPosted: Fri Feb 03, 2012 10:26 pm
ok since i think i have chosen to stay with the stock Hitachi dch-340 at least till it completely craps out on me (order a float and secondary diaphragm) are there any air cleaners that will bolt up to the factory intake flange (its 3") but since there is no center bolt on this even a 5 1/8" universal wont fit because there's nothing to hold the lid down.....
so what have any of you used aside from replacing with a Weber?
i ask because with the removal of the smog pump and vacuum lines its kind of pointless to run the stock intake...
PostPosted: Fri Feb 24, 2012 9:30 pm
You can always upgrade to the Offy intake. :) Let me know if you need one.
http://www.purerockradio.net/
PostPosted: Tue Mar 13, 2012 2:01 am
do i need one yes do i have the money for one no... ill let you know when my wallet say i can get one lol
