It is currently Wed May 27, 2026 7:27 am
 Post subject: how to check tranny oil?
PostPosted: Fri Sep 02, 2011 12:05 pm
hi! i just need help on how to check and refill the oil on the transmission of my g161?
i'm not sure if it's the same with the chevy luv since in our country it's isuzu kb. it has a m/t.
thanks in advance!:)
PostPosted: Sat Mar 31, 2012 12:31 am
if it is the same there should be to bolts on the side of your trans one higher then the other both should be on the same side. you should be able to pump in oil in the upper hole and when the lower bolt hole over flows it's full
PostPosted: Tue Apr 03, 2012 2:01 am
thanks for the reply cheeks! take care and good day!
