It is currently Tue Jun 16, 2026 8:31 am
 Post subject: smog removal
PostPosted: Sun Jul 31, 2011 10:08 am
I removed the valve and vacuum lines that connect the fuel tank, carburator, and oil pan. I'm going to need to switch to a vented gas cap correct? If so, what size cap works? A search for LUV vented gas cap returns no results.
Thanks,
Alex
 Post subject: Re: smog removal
PostPosted: Sun Jul 31, 2011 1:49 pm
There was no reason to remove that, you will not get any performance gain. As far as your intake install, look at pics on the site and do a search on the intake, its been covered several times.
PostPosted: Sun Jul 31, 2011 7:37 pm
Yeah, I wasn't looking for performance, just removing some clutter.
