It is currently Sat Jun 20, 2026 12:44 am
 Post subject: Luv Diesel
PostPosted: Fri May 06, 2011 8:24 pm
How do I find out what year size of diesel I have. Where are the numbers located on the motor. Thanks.
 Post subject: Re: Luv Diesel
PostPosted: Sat May 07, 2011 7:42 am
It won't be on the motor, but there should be a label on the driver's door frame, I think. The '81 and '82 engines are the same, but if the radiator is original, you can easily tell the difference. The '81 had a round top on the radiator, and the '82 radiator had sharper angles in the top.
Welcome to the site.
PostPosted: Sat May 07, 2011 1:05 pm
I have the radiator with the motor just no trasmission. It was ran by a hydrolic pump.
PostPosted: Sat May 07, 2011 1:13 pm
The motor has the isuzu symbol on the block. The guy I got it from said it came out of a luv truck. I just dont know much about theses things. I just wanted to get some info on it. I would like to keep it but if I cant get parts I well sale it to some one that can. Thanks.
PostPosted: Sat May 07, 2011 9:46 pm
If you're trying to ID the motor just so you can get parts, it won't matter whether it's '81 or '82.
What parts do you need, other than a transmission?
