It is currently Fri Jan 18, 2019 7:45 am
 Post subject: 4X4; differential specs.
PostPosted: Fri Apr 01, 2011 1:09 am
can any one tell me the make/model, ratio, crown wheel size, etc for a 4X4 front and rear diff?
PostPosted: Fri Apr 01, 2011 7:58 am
Australian LUV Guru
Front diff is commonly known as an 8bolt and rear is a 10bolt, ratio will be 4.555:1 (Australian Spec Luv/KB Isuzu)
http://adelaide.gumtree.com.au/c-Cars-V ... Z222567016
File comment: Rear Diffs
File comment: Front Diff Disassembled
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Apr 02, 2011 12:31 am
do you know what make the diff is? salisbury, borgwarner, etc etc
PostPosted: Sat Apr 02, 2011 1:10 am
Australian LUV Guru
Im unsure who made the diffs for Isuzu. What is it you want to do/achieve?
PostPosted: Sat Apr 02, 2011 1:18 am
looking to see if the diff gear will fit any other diffs as theyre nice and short they would be good for a 8th mile racer
PostPosted: Sat Apr 02, 2011 3:54 am
Australian LUV Guru
Diff centre looks identical to ones used in Mitsubishi L200 and Scorpion.
