It is currently Sun May 03, 2026 11:33 am
 Post subject: No break lights
PostPosted: Wed Mar 16, 2011 10:17 pm
All the other lights work fine and there's power at the back when you touch the break but when you hook it up to the lights NOTHING!!!!!!!!!!!!!!! This is a 79 with step bed HELP??????????
 Post subject: Re: No break lights
PostPosted: Thu Mar 17, 2011 10:51 pm
This sounds like a ground issue. Are the lights mounted to the fendets, if so they are fiberglass. I would run a jumper wire for a temp ground to test it. You said theres power, so it has to be a ground.
Users browsing this forum: No registered users and 2 guests
