It is currently Sat Mar 28, 2026 2:48 pm
 Post subject: 74 luv--help
PostPosted: Thu Sep 10, 2015 10:03 am
can anyone tell me where to get a rocker guide for a stock motor--new or used. i am having trouble finding parts and info-
 Post subject: Re: 74 luv--help
PostPosted: Thu Sep 10, 2015 11:24 pm
Not sure what a rocker guide is, can you explain or post a picture? I have a few head parts laying around from the last stock engine I rebuilt.
 Post subject: rocker guide?
PostPosted: Fri Sep 11, 2015 1:03 pm
yah---its the part that sits on the end of the valves after the valves are assembled. its round with a slot for the rocker arm to ride in------this is the overhead cam motor---thanx
 Post subject: Re: rocker guide?
PostPosted: Fri Sep 11, 2015 8:28 pm
Now this is the third new thread you started on this topic. The rocker guide you need is the same for a 72-75 LUV. This is the early engine and not a lot around for parts. My best advise is to locate one in a junk yard, this might be your only bet.
Also, all stock LUVs had overhead cam engines.
PostPosted: Fri Sep 11, 2015 9:18 pm
I merged the 2 topics your conversation is in.
