It is currently Tue Jun 16, 2026 5:16 am
 Post subject: Dash lights
PostPosted: Fri Aug 28, 2020 4:33 pm
I needing to know if there is anyway at all to check the dash lights on a 1975 chevy luv dash? All my bulbs are new I changed them all out because I didn't want to take a chance on putting the gauges back in and them be burnt out. Im not having any luck with them. I've got fire up to the gauges and going out to them I just don't have any dash lights. Any info will help. Thanks guys!
 Post subject: Re: Dash lights
PostPosted: Tue Sep 01, 2020 12:23 pm
Are you sure you have ground? Not trying to insult you with a stupid question, just trying to help.
Did you install LED bulbs? They have to have the + and - correct. I found this out when only half my new trailer lights worked.
PostPosted: Wed Sep 02, 2020 6:14 pm
Rondog ive checked all my grounds and they all are connected. Ive get all places where fire comes in and I have come to the conclusion that the circuit board on the back of my dash either has a hair line crack in it or it has just plan went bad. Thank you for the response. I will check them again to make sure.
