It is currently Tue Jun 16, 2026 5:17 am
PostPosted: Mon Dec 23, 2019 12:42 pm
Hello again. I'm wondering where the best source for parts might be for the 1.8l. I'm wanting to bore the motor .60 over and was considering forged aluminum rods and pistons. I may also need a new crank shaft. Is there anyone or another crank that might give me more displacement? I'm also wondering where I might find a cam that would complement a turbo setup because I may go that direction in the future. Thanks for your time.
PostPosted: Mon Dec 30, 2019 1:10 am
cheaper would be an isuzu 2.3L with a weber and headers. youre lookin at a seriously expensive setup thatd all be custom made, some aftermarket is available from Australia. check out turbo gemini .com youd have an easier time and make more power cheaper swapping in something else like a nissan sr20det or ca18det, many options that you can make mounts to fit and get a better end result.. but isuzu impulse turbo manifold will mount to your stock head i had one for mine but theyre very hard to find and prone to cracking
