It is currently Tue Jun 16, 2026 5:17 am
PostPosted: Tue Nov 28, 2017 6:01 pm
Hi. I bought a 1981 Luv. I bought 6 lug Nissan rims, which I thought should fit, but they won't fit over the disc brakes/callipers. Would a wheel spacer work to solve the problem?
Advice please?
PostPosted: Wed Nov 29, 2017 7:46 am
I’ve never heard of this problem. Are they Titan rims? Usually, it’s the rims’ center bore that’s the problem. I’ve read 100mm is required, and I’ve read 108mm — so best to measure.
I doubt spacers will help, because they’d probably stick out from the fenders (depending on the rim width and offset).
