It is currently Tue Jun 16, 2026 6:22 am
PostPosted: Sun Sep 28, 2014 7:51 pm
Hello, Does anyone have some pics of the dual exhaust routing? It seems that it is going to be very tight by the fuel tank.
Thanks,
Eric
PostPosted: Sun Sep 28, 2014 9:23 pm
Not a good pic but here is mine.
PostPosted: Mon Sep 29, 2014 11:26 pm
Thanks for the pics!
PostPosted: Fri Oct 03, 2014 10:27 am
I do not have a picture, but some of the V8 swap guys route their exhaust to the same side so they can keep their stock fuel tank. I am going to do that to my V8 Luv so I can put the Stock tank into it. Chevy had to put a shield between the exhaust and the starter so the BBC would start after sitting a short time. Good muffler shop can do what you want. You could make a shield to go between the tank and pipe.I would think the muffler might be willing to that. I would think they would use a larger pipe to put over the pipe they use on the pipe that they use to build your exhaust. That is not a bad Idea now that I thought of it. I may do something like that when I have my pipes redone. Several companies make exhaust wrap that you could use on the pipe by the tank.
Maybe someone with a stock and V8 pipes will post a pic. You might post the question in a different section as not everyone checks the newbie section.
Users browsing this forum: Bing [Bot] and 9 guests
