It is currently Tue Jun 16, 2026 7:33 am
 Post subject: 1976 Luv
PostPosted: Mon Oct 29, 2012 6:05 pm
Have a 76 luv with an electric choke carburetor but the connector was cut off the wiring harness. Does anyone knw where I can get another connector or wiring harness and I would like to find another Carb that's in better condition then mine.
 Post subject: Re: 1976 Luv
PostPosted: Tue Oct 30, 2012 6:21 am
I have a stock Carb that worked great. I pulled it to put on a Weber. What a power difference!!! I would recommend investing I'm a Weber. If you are still interested in a stock Carb I have one cheap.
PostPosted: Tue Oct 30, 2012 6:12 pm
Do you need the engine harness side or carb side?
PostPosted: Thu Nov 01, 2012 3:39 pm
I need the engine harness side but I figured if I can't find the connector I would wire it direct by cutting the connector off the carb
PostPosted: Thu Nov 01, 2012 3:58 pm
Which model Weber would I use for this truck?
PostPosted: Thu Nov 01, 2012 4:32 pm
I used the 32/36 DGEV. Here's the link to the redline site.
http://www.redlineweber.com/carb-kits/auto/chevrolet/
PostPosted: Thu Nov 01, 2012 5:35 pm
Thanks I'll check it out
PostPosted: Fri Nov 23, 2012 4:22 pm
Just curious...are the Toyota 20R/22R hardware the same as what would come in a kit?
My House Is Guarded By A Shotgun 3 Days A Week. Guess Which Days.
PostPosted: Thu Oct 02, 2014 2:29 am
its the engine harness side. do you know where i can get another one?
