It is currently Tue Jun 16, 2026 6:22 am
 Post subject: Tranny swap
PostPosted: Sun May 25, 2014 7:42 pm
Hey guys I have a 1974 mikado and I'm tired of the 4 speed tranny... anyone know what 5 speed I can swap it out for that won't required too much modifications?
 Post subject: Re: Tranny swap
PostPosted: Sun May 25, 2014 11:40 pm
No offense, bradybrat, but this question comes up often, and is perfect for our search engine, located at upper right.
You are looking for a Isuzu MSG 5 speed transmission, preferably from a 86-87 Isuzu Pup, but there are other donor vehicles as well.
Here is a link to the search in question: search.php?keywords=5+speed&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
You should find all the answers you need in there.
PostPosted: Mon May 26, 2014 6:52 am
That fit the early engines?
PostPosted: Mon May 26, 2014 1:30 pm
Is it really 75 or later for the 5 speed swap??
I realize the starter bump and the clutch switch sides at a certain point, but don't all the years have essentially the same bolt pattern? Are Series 1-3 transmissions different?
PostPosted: Mon May 26, 2014 5:15 pm
Thanks... does it matter what transmission model? Like MSG-5E, MSG-5ET, MSG-5K, MSG-5T
PostPosted: Mon May 26, 2014 6:52 pm
It has to be the later G180 engine. The flat valve cover engine. The early engine with the pyramid looking valve cover has a differant transmission bolt pattern.
PostPosted: Wed Jun 04, 2014 7:54 am
Cool.. thanks a lot!
Users browsing this forum: Bing [Bot] and 9 guests
