It is currently Tue Jun 16, 2026 6:20 am
PostPosted: Sat Mar 01, 2014 11:33 am
I hope I'm not asking too many questions on here since I'm new to the sight, but I just got my Luv and while it's sitting idling it smokes from the engine and the tail pipe. My plan is to rebuild the engine as I go through the process of restoring the truck, but I wanted to see if anyone has a good answer/solution for this since I was hoping to drive it some in the condition in its in before beginning the full resto. Thanks!
PostPosted: Sat Mar 01, 2014 12:03 pm
Smoke can be steam, like a blown head gasket, oil burning due to rings or valve guides or something as simple as a PCV system clogged. You will need to do a bit of work to figure out what it is.
PostPosted: Sat Mar 01, 2014 12:13 pm
Would trying seafoam or changing the oil help? Would you suggest a heavier oil or Lucas additive?
PostPosted: Sat Mar 01, 2014 1:32 pm
Where os the smoke coming from when it comes from the engine
PostPosted: Sat Mar 01, 2014 1:59 pm
Around the exhaust manifold it seems.
PostPosted: Sat Mar 01, 2014 5:15 pm
There's a draft tube on the passenger's side of the engine, and it's normal to see some smoke coming from it. On the diesels, that is.
PostPosted: Sat Mar 01, 2014 5:18 pm
This is gas and the smoke is on the driver side mainly. Thanks for the replies.
PostPosted: Wed Mar 05, 2014 4:04 pm
What color is the smoke coming from the tail pipe? Pure white is steam, blue is oil burning, and black is running rich (too much gas getting in the engine)
Also, on the smoke from the engine area, is there quite a bit of oil mess around and over the exhaust manifold? Is that what is smoking once it gets hot or is it coming out around the manifold where the exhaust pipe hooks on? Does it start smoking near the engine immediately after starting or only after it gets well warmed up?
If it is white smoke and LOTS of it, then you are probably looking at a head gasket problem. Check the oil to make sure it is not getting milky from water getting in it, and check the coolant in the radiator for signs of any oil in it too.
PostPosted: Wed Mar 05, 2014 4:20 pm
The smoke from the tail pipe is mainly white as is the smoke from the engine. The engine is pretty oily but the smoke starts well before its had time to warm up. The oil is pretty watered down too. I'm going to do a full resto on this truck but was hoping to drive it around a little while before overhauling the engine. I guess that's out the window now. Thanks for the reply.
PostPosted: Wed Mar 05, 2014 5:16 pm
Sounds likely to be a head gasket or possibly cracked head. My 79 was like that when I got it, and it did smoke/steam quite a lot around the exhaust manifold and pipe too. I was surprised at the time how much, but I guess the steam shows at every leak, where just exhaust is not as visible.
Hope you get it going. There are plenty of head gasket threads here and lots of info and tips in them. If you have all the parts ready it really isn't too hard of a job to do.
PostPosted: Wed Mar 05, 2014 6:14 pm
Seconded. Replacing gaskets is common when you first buy one of these - Especially if it has been sitting for a while. You could run a compression test on each cylinder to figure out if you're headed in the right direction, but honestly, you should just do it right and get down in there.
