It is currently Tue Jun 16, 2026 6:27 am
PostPosted: Tue Nov 05, 2013 9:14 pm
I have a 1979 chevy luv Mikado the voltage regulator has gone bad. so my question is it best to replace the alternator with a built in voltage regulator or just replace the voltage regulator? the voltage regulator is very pricy and about the same cost as a alternator with the regulator built in it. and what is the correct way to run the new wires for the alternator with reg built in. or does anyone no of a cheap place to buy voltage regulator. thanks for help
PostPosted: Wed Nov 06, 2013 12:06 pm
I would stay with the stock regulator just to simplify everything. The wiring is already there and the regulator also controls the electric fuel pump operation. No mods needed. My thoughts.
PostPosted: Wed Nov 06, 2013 1:20 pm
I would keep it stock. I see NAPA has 2 regulators, one for $60 and one for $35. I did modify my stock wiring harness to accept a GM alternator with a internal regulator, not a big deal but then you need to decide what to do with the fuel pump wiring like the above reply has mentioned. Again, if the truck is stock I would buy the replacement regulator, since my truck is modified from the front to back I went with the bigger amp GM alternator and did a separate circuit for the fuel pump.
