It is currently Tue Jun 16, 2026 6:21 am
 Post subject: dual head lights
PostPosted: Mon Aug 12, 2013 10:27 am
hey guys i was wondering how hard it would be to switch from single to dual head lights. new grill maybe new radiator supports
78 LUV [soon to be]
 Post subject: Re: dual head lights
PostPosted: Mon Aug 12, 2013 7:01 pm
It bolls right in. You don't need to change the radiator to swap to the 4 headlight system. You will need to read the wiring schematic and re wire as necessary, it might include a couple more fuses.
PostPosted: Tue Aug 13, 2013 9:03 am
k thx cause im kinda liking that look more and if its not that hard to swap then i most likly will
78 LUV [soon to be]
PostPosted: Fri Aug 16, 2013 1:46 pm
It is very easy. From the donor Pull the grill, headlight trim, the headlight buckets that are attached to the radiator core support, the lights themselves, and grab the last couple feet of the wiring that plugs into the 4 head light bulbs. With the wiring harness you can put flat spade plugs on the three wires and just plug them into the plug that used to hook to the two headlight bulbs. One is a ground, one is low beam power (goes to just one of the two plugs) and the third is high beam power. My 79 it worked fine without worrying about extra fuses. The two headlamp system uses thermal circuit breakers under the dash to protect the headlight circuit instead of the four fuses used by the four headlamp system. In my case at least, the circuit breakers handled the four bulbs just fine.
Another good upgrade would be to install relays and heavier wiring going from the bulbs directly to the battery. Use the original wiring to drive a relay for high beams and another for low beams. There should be a fuse between the battery and each relay. The direct power run over heavier shorter wires to the bulbs results in more voltage reaching the bulbs.
Users browsing this forum: Bing [Bot] and 8 guests
