It is currently Tue Jun 16, 2026 6:20 am
 Post subject: Stock AM Radio
PostPosted: Mon Jun 10, 2013 9:29 pm
I've got an old Fujitsu Ten Limited AM radio, with the LUV logo in front, that I want to install in an 81 LUV. I'm trying to figure out how to wire it. It's got two prongs in the back (see pictures), and I'm not sure where to start. Is there a special adapter made for this kind of radio? Any thoughts appreciated.
Thanks!
 Post subject: Re: Stock AM Radio
PostPosted: Mon Jun 10, 2013 11:44 pm
12v power would connect at the fuse area. The two round prongs would be the speaker connections. Lower left hole of course would be the antenna connection.
PostPosted: Tue Jun 11, 2013 9:42 am
Ok thank you. Do I need to open the fuse box to find the wiring?
PostPosted: Tue Jun 11, 2013 10:36 am
It looks like there is a little metal tab at the end of the fuse, the left in your picture. The single power wire (stock wire is usually blue in most of the LUVs I've seen) should just plug right on to that tab if I'm not mistaken. The radio will get a ground through its frame, so for testing you will need to wire the frame to a good ground.
PostPosted: Tue Jun 11, 2013 11:12 am
Ah, I see, seems simple. Thank you!
Last question on the radio....any suggestions for installation? Is there a particular install kit that works best?
Thanks again.
PostPosted: Tue Jun 11, 2013 11:47 am
X2 on above.
PostPosted: Tue Jun 11, 2013 12:00 pm
Here's a couple of pics of the stock mounting brackets for the 2 knob decks.
In the first pic the bracket on the left is raised up so that you can see exactly how they function.
The brackets mount under the knobs on the radio,then they bolt to the dash under the deck.
PostPosted: Tue Jun 11, 2013 12:21 pm
Awesome....thanks! Do you know where I can get a pair of those mounting brackets?
PostPosted: Tue Jun 11, 2013 12:56 pm
Your best bet is to make them yourself using bendable brackets that you can get at any hardware store. Or you can wait and see if anyone has a set that they can part with.
