It is currently Tue Jun 16, 2026 7:36 am
 Post subject: Diverter valve
PostPosted: Tue Jan 03, 2012 8:47 am
Hi im Eric and I have a 1980 Luv 1.8 2wd 4spd and my mechanic says I need an air diverter valve, I cannot find 1, is it the same as the air check valve or does it have another name? Thank you.
 Post subject: Re: Diverter valve
PostPosted: Wed Jan 04, 2012 8:27 pm
Diverter valve is the correct name. It is part of the air pump smog control system. When you are coasting with the throttle closed it "diverts" the air from the tubes in the exhaust manifold to the engine intake system, to lean out the mixture and eliminate backfiring.
PostPosted: Sat Jul 21, 2012 10:54 am
any luck in finding this i need it too the mechanic says. Please help. trucks been at the shop 3 months now
What part is this?
What is it for?
How Do I test it?
Where do i get a new one?
Are we there yet??
PostPosted: Sat Jul 21, 2012 11:28 am
Post pic of said part...
