It is currently Tue Jun 16, 2026 7:38 am
 Post subject: Strange horn problem
PostPosted: Thu Mar 15, 2012 9:41 pm
Using a jumper wire, i can ground the spring loaded contact behind the steering wheel and the horn honks. The center of my steering column isn't grounded. how is this even possible?
while the pessimist and optimist were arguing about the glass of water, the opportunist drank it.
 Post subject: Re: Strange horn problem
PostPosted: Fri May 04, 2012 2:57 pm
Well the steering column IS grounded. Maybe the little brass or bronze contact above the spring is worn to the point that it no longer makes contact thru the horn button.
82 C 223 250K. Runs as new except the crap transmission.
PostPosted: Fri May 04, 2012 7:35 pm
There I'd a part called a cross strap at the steering coupler that grounds the steering shaft.
PostPosted: Thu Jul 12, 2012 2:07 pm
luvrv8 had the answer nailed! i had rust built up in the coupler disc and the little spring that lives inside it. took it apart, removed the rust, re-assembled, and now the steering column is grounded and the tiny horn honks. thanks guys!
