It is currently Tue Jun 16, 2026 7:36 am
 Post subject: 350 swap
PostPosted: Sat May 19, 2012 10:49 am
how easy would it be to do a 350 swap with a 78 :signanyone
78 LUV [soon to be]
 Post subject: Re: 350 swap
PostPosted: Sat May 19, 2012 1:17 pm
I dont think anyone has ever done that before. :esurprised
This is the 2nd greatest link ever (to find your answers)
http://forums.luvtruck.com/search.php
ps welcome.
PostPosted: Sat May 19, 2012 1:53 pm
well i dont know yet if its going to be a 4.3 or a 350 but im going to sell the 4 cylinder thats in my 78 now and get one of the two
78 LUV [soon to be]
PostPosted: Sat May 19, 2012 4:10 pm
well i think a 350 is going to heavy so im going with an ls1 :offtopic
78 LUV [soon to be]
PostPosted: Sat May 19, 2012 4:11 pm
does anyone know where i can pick one up chaep
78 LUV [soon to be]
PostPosted: Sat May 19, 2012 4:39 pm
It's hardly too heavy. It's been done countless times. Check out the v8 swap article here ----> http://www.luvtruck.com/pdf/EngSwap.pdf
PostPosted: Sat May 19, 2012 5:15 pm
an ls1 weighs about 424lbs and the 350 weighs 521lbs thats a lot of weight between the two
78 LUV [soon to be]
PostPosted: Sat May 19, 2012 6:55 pm
What you loose in weight, you will make up in $$$$. What are you trying to accomplish that almost 100 lbs would hurt? Don't get me wrong, an LSx type swap would be great if you can afford it.
Either way, check http://www.powerbyace.com out.
PostPosted: Sat May 19, 2012 9:13 pm
Jedi Pimp Master
Older 350 stuff is becoming more pricey but if your looking for a "cheap motor" look at wrecked Chevy Trucks and look at Buick RoadMasters as both come with LT motors and some of the RoadMasters had LS motors. Bought my last two RoadMasters for $800 and $1000 both drivers with strong motors.
SRAD
My Wife is faster than you think you are
PostPosted: Sat May 19, 2012 9:49 pm
thx guys i will start looking
78 LUV [soon to be]
PostPosted: Sun May 20, 2012 1:19 am
100 pounds is a lot of weight? Ever carried a passenger in your car?
This site has a plethora of information on small block swaps if you take the time to look through it. Companies make kits for the small block swap. If you're looking for cheap, you probably shouldn't be looking for an ls. The truck can withstand the weight of a sbc just fine.
PostPosted: Sun May 20, 2012 7:32 am
good point
78 LUV [soon to be]
