It is currently Tue Jun 16, 2026 8:41 am
 Post subject: distributor??
PostPosted: Mon Apr 16, 2012 10:54 pm
rotor in distributor not turning what do I need to do to repair? I assume there used to be a gear on the bottom of the shaft. there is not one. where would this end up in the engine? this may be a dumb question but it has me stumped.
 Post subject: Re: distributor??
PostPosted: Mon Apr 16, 2012 11:37 pm
The gear stays in the engine. It drives the distributor via a slot the distributor shaft fits into. The same gear also drives the oil pump so that will not operate also. I suspect a key is sheared or drive pin broken at that gear which means the pully, front timing cover, and oil pan has to be pulled for access and repair.
PostPosted: Tue Apr 17, 2012 6:15 am
thanks for the help
