It is currently Wed Jun 10, 2026 2:15 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Feb 04, 2012 5:18 pm
Get a replacement bolt in hand take the truck to a shop. With the vehicle on a lift and a professional mechanic with a box of tools it should be a quick fix. You might get charged a hour labor, that is cheaper then a rebuilt transmission
PostPosted: Sat Feb 04, 2012 7:37 pm
thats why i have a 4" pipe wrench the jaws open to i think 1.5" and theres very few places i cant use it....
heres my advice... and this doesnt come out often pay some one else to do it.... yes i agree its more gratifying to repair stuff your self but from the sounds of it you dont have the tools or the ability to get your self out of a sticky pickle you find your self in... shop cost to pull the bolt $60-$100 cost to fix transmission thousands... theres no priceless in this situation
PostPosted: Sun Feb 05, 2012 1:54 pm
yeah, I decided after going at it with a pipe wrench and failing, I am going to take it to shop.
PostPosted: Wed Feb 08, 2012 11:01 am
on the fill plug the pipe wrench will work. It supplies more torque than locking pliers as the more you turn the tighter it gets. And i add 2.5 pints to my luv. Same year. Through the shifter after i drain. But i remember now my drain plug was stuck and i took it to the shop and they had it out in no time and didnt charge me anything. Good luck buddy.
Luv my Luv? I do!
