It is currently Tue Jun 16, 2026 7:40 am
PostPosted: Sun Jan 08, 2012 6:20 pm
What is the trick to spinning the star wheel to adjust the rear shoes? The thing won't budge and my new drums wont fit over my new shoes.
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Sun Jan 08, 2012 6:58 pm
It may be froze. I often replace much of the hardware on a reline. Also rebuild the wheel cylinders and calipers every few brake jobs. I would replace it if you can find a new one. Otherwise, remove it, give it a good shot of penetrating oil, and a rappy tap tap with a small hammer. Then work at turning it. Repeat as needed. Once it is freed up, coat the threads with graphite or a light coat of Sil-Glyde.
PostPosted: Sun Jan 15, 2012 7:14 pm
Thanks for the tips! Soaked it in some PB Blaster, re-lubed it, now it works like new.
