It is currently Tue Jun 16, 2026 8:36 am
 Post subject: Manual choke cable issue
PostPosted: Tue Nov 29, 2011 2:26 pm
I have a 79 Luv and the cable that pulls in and out for the choke disconnected from the carb. Where the heck to I attach the cable for the manual choke. The motor is running very rough and I'm worried that the choke is stuck either too far open or closed too much. Any help is appreciated.
PostPosted: Tue Nov 29, 2011 3:15 pm
You sure you have a 79? Mine is an electric choke. Never the less the choke should hook up to the lever that positions the damper on the top of the carb throat
PostPosted: Tue Nov 29, 2011 3:16 pm
yep its manual I can see the wire pulling in and out when I move the choke knob from the cab. Thanks For some reason the manuals I have are very vague on the exact spot the cable attaches.
