It is currently Tue Mar 03, 2026 9:40 am
PostPosted: Tue Jun 07, 2011 7:52 pm
:?: Im stumped... My truck began losing power while driving one day, 55mph top speed even w/ pedal to the floor. Then about a month later it was 45mph, then 35mph the month after that.... until one day it dropped to 5mph then 0. Now, it wont budge yet starts & runs just fine. what the heck?..someone said it might be the clutch?.... I have no idea where to start? Clutch pushes in, it seems to feel as if it goes into gear, but when you let it out, it does nothing..... no noise, no grinding, no movement,... no nothing. Yet everything else seems totally fine.......... :?:
PostPosted: Wed Jun 08, 2011 1:06 am
if the motor will rev up wen u hit the gas and it jus wont move its probably a trans problem
PostPosted: Wed Jun 08, 2011 1:57 am
Yep, sounds like the clutch...
PostPosted: Wed Jun 08, 2011 10:59 am
Thanx! Alot! I sure hope it is the clutch. I just didn't want to tear into anything without fully knowing for sure or not. The clutch is internal in the tranny...... Sounds scary! I am working on it alone... so, if i run into anyhting else i'll be writting back on here. *^__^*
