It is currently Tue Mar 03, 2026 9:41 am
 Post subject: Resistor Bypass Relay
PostPosted: Tue Apr 26, 2011 8:15 am
I just installed a Weber carb, but think I have an electrical gremlin that is causing it not to turn over (not getting any sparks). Taking a multi-meter through the ignition circuit, I show 12V going in, but less that a volt coming out of the other terminals. Reading other posts in the forum in, I have a bad relay. I've read where the best option is to replace the OEM relay with a Bosch 40A relay, but is there a specific part number I should use? Also, I'm assuming the connector needs to be replaced - any suggestions on that?
PostPosted: Wed May 18, 2011 6:12 pm
Do a search on the fuse box issues and do the fuse box fix before you do any other work. Its easy and it solves problems that you would not think have anything to do with the fuse box. Note that the fuse that is labeled "regulator" also controls the fuel pump and the coil.
