It is currently Tue Mar 03, 2026 9:41 am
PostPosted: Fri Apr 01, 2011 10:52 am
I'm looking at a '78 right now and it has a problem with the wipers and radio sometimes working and other times not, and unfortunately that will keep me from passing inspection. I was wondering if this is a common problem with Luvs? Is it likely just a simple short that needs to be replaced or the sign of something bigger?
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Fri Apr 01, 2011 1:47 pm
Sorry, I was probably a little hasty in asking this. I just found the wiring diagram on this site and see where the radio and wiper motor have a common wire and I'm guessing that's the culprit, likely loose somewhere along the way.
While I've got your attention, what are some common problems with these trucks I should pay close attention to? I'm trying to make myself a check list so I can be as thorough as possible.
Thanks,
Alex
PostPosted: Fri Apr 01, 2011 8:52 pm
It is almost 99% your fuse box.... it is the last fuse closest to the firewall. Get ya some lemon juice and a tooth brush and put some on there and scrub the holding pieces for the fuse with the toothbrush. Bet ya it works for ya too
PostPosted: Fri Apr 01, 2011 11:07 pm
Awesome, thanks for that tip Jeremy! I'll be sure to bring a toothbrush and a lemon with me when I go to check this truck out in the morning.
PostPosted: Sat Apr 02, 2011 8:13 am
let us know how it goes... good luck to ya
PostPosted: Sat Apr 02, 2011 10:46 am
Yeah, the fuse box. I fought electrical problem for at least 20 years before nailing the culprit. LUV's have a weak link in the electrical system, the fusebox. The terminals the wires connect are riveted to the fuse holders. A little age and corrosion, and you get electrical intermittents. I solved mine by taking it apart and soldering the joints. Others have cleaned it with lemon juice, and others a new fuse box.
PostPosted: Wed Apr 06, 2011 6:24 pm
The fuse box was the culprit, thanks for the help y'all. I ended up buying the truck as well, I'll get some pictures up once I get my camera back from my folk's place.
PostPosted: Wed Apr 06, 2011 7:34 pm
Good show... glad all worked out for ya
