It is currently Tue Mar 03, 2026 9:43 am
PostPosted: Fri Mar 25, 2011 6:17 am
hi i have a 72 luv in peices that im trying to reassemble and turns out i need new wiring and a new harness i checked out a couple sites but am not still sure what exactly i need, the trucks only needing reverse/tail/break/headlights signals/hazards fuel pump, cooling fan, guages, and radio. also just an idea is it possible/ worth it to use the harness out of a 92 rodeo? thanks
PostPosted: Fri Mar 25, 2011 1:07 pm
You could start there. It will be a lot of work. Try replacing the 6 in http://www.luvtruck.com/PDF/Series6.pdf with whatever is the right series number for your 72.
PostPosted: Fri Mar 25, 2011 9:57 pm
Well 72 is series 1, and I'd recommend just using wire and connectors to rebuild the harness according to the wiring diagram, there aren't that many. I guess you could buy a universal one.
PostPosted: Fri Mar 25, 2011 10:56 pm
yeah i looked at some universal ones today and i think thats what im gonna have to go with, i have no electrical experience besides stereos and speakers. the harness i was looking at is really simple but it said in prewired circuits one of them was Electric Fuel Pump/Cooling Fan. does that mean i run both on the same circuit? can i post a link to it or am i not allowed to? thanks for the help guys
PostPosted: Sat Mar 26, 2011 9:45 am
you might try http://www.autowiringsolutions.com/item ... ory_id=134
its a good all around system . i used it on a 75
PostPosted: Mon Mar 28, 2011 10:43 pm
I know on the 72's the back lights were under the tailgate, but a harness from 75 should still work, right? If so I may have one for you.
PostPosted: Tue Mar 29, 2011 6:34 pm
thanks for the help i went with auto wiring solutions and now ill be able to add more down the road
PostPosted: Sat Apr 02, 2011 1:28 am
so when i checked it turns out all the accessory wires are still there but nothings labeled from when they pulled the old harness so i was wondering if anybody knew of a color coded diagram so then i can just do a quick match up and be done with it
