It is currently Sun Mar 29, 2026 12:02 am
 Post subject: in tank fuel pump?
PostPosted: Thu Feb 06, 2003 7:36 pm
is there an intank fuel pump? and if so how hard is it to get out? have n e of u taken out the tank to clean it? is it hard? if u can't tell i have a fuel probablem. it ideals and will run fine sometymes and other tymes it acts like its running out of gas and i have been tryin to figure out what it is i have changed fuel filters 1 fuel pump off my 80 luv cleaned the lines put new hoses where i needed them and i am still stumped. n e help will be greatly appreciated. oh ya i have the stock motor and its a 78
PostPosted: Thu Feb 06, 2003 8:29 pm
No, there shouldn't be a pump in the tank, that is only will fuel injection that need high pressure pumps. The only one is one the crossmember at the back of the cab. As for the probs, I really wouldn't know what to tell you except maybe check the ground at the pump to see if you are getting full current.
PostPosted: Thu Feb 06, 2003 8:59 pm
maybe pull the gas line off the carb and turn the truck on. no fuel, then like tilted said, check into the fuel pump, ground, power, fuse,etc.
PostPosted: Thu Feb 06, 2003 9:04 pm
after consulting my trusty hanes book, it has come to my attention that there is a fuel pump relay. One of those little square jobs tucked close to a fender wall or somewhere( i dont remember- mine are history due to the trusty painless kit). hope that helps.
PostPosted: Fri Feb 07, 2003 12:14 am
The relay if you still have it is on the right fender. I had to just finally give up on mine... my original fuel pump that is. I looked and looked for another relay and I could not find one at any parts store anywhere, so I figured that I would have to go to an aftermarket fuel pump so I bought a universal fuel pump and ran a power wire and a ground to a toggle switch and voila fuel pump problem solved. Hope this helps a little !
