It is currently Sun Jun 28, 2026 3:00 pm
 Post subject: Post your stereo set-ups
PostPosted: Fri Dec 23, 2005 7:00 pm
Hey, just wondering if anyone crammed some subs and amps behind their seats like I'm trying to do now. Anyways, post up your aftermarket stereo set-up, even if it's just a cd player. Post pics too. :)
PostPosted: Fri Dec 23, 2005 9:08 pm
not mine but cool anyway
PostPosted: Fri Dec 23, 2005 11:42 pm
is that in a luv?
I'll have pics of mine up in a few minutes
edit- here's mine. I found some old MDF board in the garage so I thought I'd use it. I don't really like the way it looks in here so I'm gonna rip it out and completely redo it, but it will be the same basic concept (with a little more planning). The box is just sitting in there, not anchored down, and not hooked up. Anyways, on with the pics
PostPosted: Fri Dec 23, 2005 11:55 pm
is your stock fuse box and alternator/generator pushing all of your stereo systems cause i cant get my cd player to keep a memory when i turn my truck off. and also when i'm going it works but soon as i let off of it and it idles down the cd player/radio cut off. so i was wandering how yall got all that stuff to work with stock luv wiring.
PostPosted: Sat Dec 24, 2005 12:28 am
Yes that’s a luv it was from one on eBay for sale a while ago.
My son has a 1000watt system in his with a sub and booster and he hasn’t had any problems with his turning off or anything
PostPosted: Sat Dec 24, 2005 12:55 am
If I were you I would run new wires, it's a quite simple project. Run one from the deck to your battery, that will be your constant and hold your memory. Then run one to a wire or fuse that turns on with your car, that's basically just an on/off. If you run new wires for those two that should fix your problem. The alternator has nothing to do with keeping memory or anything like that on your cd player. Everything is basically ran from the battery. If your alternator was old and not working as well as it should then you would notice your lights dimming and stuff like that, but not memory loss and etc...
PostPosted: Sat Dec 24, 2005 10:32 am
There should be a wiring diagram in your owners booklet you got with the player, unless you bought it second hand, then just look up the model no. on google and it should pull up one.
For my sys.
http://forums.luvtruck.com/viewtopic.php?t=6652&highlight=receivers
PostPosted: Sat Dec 24, 2005 8:44 pm
so if im driving and it starts cutting on and off i probably have a short in the power wire for the cd player right? or is it something else. nothing is wrong with the player cause i took it out and put it in my friends car and it worked fine. :?: :?: :?:
PostPosted: Sat Dec 24, 2005 10:30 pm
yep, that's most likely it
PostPosted: Wed Dec 28, 2005 7:18 pm
yo kicker, thanks man i ran new wire today and the radio stays on and it has memory.
PostPosted: Wed Dec 28, 2005 9:05 pm
good man, glad I could help
PostPosted: Fri Dec 30, 2005 4:23 pm
Here's mine
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Dec 30, 2005 8:51 pm
Hole-lay-crap!!!
PostPosted: Sun Jan 01, 2006 5:44 pm
Undefeated in Trivia
Dan wrote:
Here's mine
Any particular reason you layed the speakers in like that?
PostPosted: Sun Jan 01, 2006 6:45 pm
I wanted to put the sub in the middle but there was no room because it was too deep, and Im using the stock bench seat.So I had to put in a lower postion so I could still use it.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Jan 01, 2006 10:33 pm
How thick is it, there are slim subwoofers you can buy that are 2" to 4" thick out now, most are 12" subs and'll cost you $100+ for em'
PostPosted: Mon Jan 16, 2006 2:43 pm
LSX LUV Owner
i had a cd player and 2 3.5"'s each one behind the stock ac vents and 2 6.5's behind the seats in some bootleg boxes.. was better than nothing.. i dont own the truck anymore.
u can see the 3.5's behind the vents.. only pics i found of them..
no pics of the 6.5's behind the seats but heres when i 1st had 6x9's in the sides of the cab...
