It is currently Wed Jul 01, 2026 7:10 pm
 Post subject: Finally !!
PostPosted: Tue Jan 21, 2003 6:54 am
Well I finally fired up my luv this last weekend :D , it drives but needs a little adjusting, but at least its running. The disc brake conversion is definately a big improvement and is worth every penny. Now I get to find out if my stock rear end will hold up for awhile. :roll:
PostPosted: Tue Jan 21, 2003 10:11 am
what disc break set up did you use????????
PostPosted: Tue Jan 21, 2003 7:14 pm
disc brakes...? what?? do tell.
PostPosted: Fri Jan 24, 2003 4:12 am
I was talking about the front brakes...i had the drum setup and i swapped them out with the disc setup off of a newer LUV....there's an article about it in the information section of luvtruck site.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 37 guests
