It is currently Tue Jun 30, 2026 3:00 am
 Post subject: odd luv truck on fwy
PostPosted: Fri Jan 03, 2003 11:47 pm
Today I saw an odd luv truck, it was a later model [ single headlights ] it was longer than others I have seen by about 3 1/2 ft it had a cab extension that looked like it was attached to the original the extension had the exact same contours as the cab [line on door to bed ]
the bed was normal length but had fenders on it the same as a step side again they looked factory , they fit the body contours perfectly
it said mikado on the side the whole thing looked like a baby version of the early full size crew cab dually trucks of ford /chevy but with no rear doors or dual wheels but the rear axle looked wider than normal
I was in my courier and buzzed around him looking at all I could see till he got nervous and off I went what do you guys think ????
PostPosted: Sun Jan 05, 2003 10:37 am
I havent a clue, but, sounds like a rare sighting. How cool would that be, you could build a motor for that, and haul your whole family around in it. You know, if you see it more ofter, you should try to get a digital and post it, I would find it interesting.
g
Users browsing this forum: Majestic-12 [Bot] and 30 guests
