It is currently Mon Jun 29, 2026 9:45 pm
 Post subject: Camber angle
PostPosted: Sat Dec 21, 2002 11:26 pm
well when i lifted my luv today i pulled the sway bar for better articulation.
But now i have some negetive camber angle on the truck and i was wondering if this is correctiable or should i hook the sway bar back up?
PostPosted: Sun Dec 22, 2002 4:05 pm
the swaybar does not effect camber angle ,the ajustment is on the upper control arm you should take it to a aligment shop so they can set it .ps the more shim you take out the of the upper control arms to frame bolts the more positive the camber changes-as you change camber the toe also changes hope this helps
PostPosted: Sat Dec 28, 2002 8:05 pm
i finally got my truck aligned. The exsesive camber angel was becouse my bars rattled in too far they said, so they had to lower them about 1/4". So now my truck isnt running on the top out stops all teh time and the bars arent as tight so it rides alot better now.
