It is currently Fri Jun 12, 2026 11:34 pm
PostPosted: Fri Dec 20, 2002 9:10 am
:lol: HI there every one, i was thinking of installing a tilt wheel into my luv, and wanted to know if anyone has done this before and could give me a step by step way of installing it in to my luv, i have one that i took out of my 74 vega and want to try to use it , it only has the ignition/wipers horn,
but that all i want, so is anybody real good at the elect hookup,,, i still have all the wireing from the vega , and it would be nice to have a better ignition switch for the truck, at least it would lock and be a little harder to steal, right now you just have to uplug and go.. by the way i''m not and elect wiz so please keep it simple, all your help would be greatly apperciated...thanks again MATT
PostPosted: Fri Dec 20, 2002 2:01 pm
you may want to talk to RATNLUV about this.
my advice is to draw a diagram before you start. things are much easier that way.
find out what color goes where on the column, then find out what wires you need to splice into on the original wiring.
then draw the diagram for both showing where to splice into them.
03Cobra
