It is currently Fri Jun 12, 2026 10:20 pm
 Post subject: lift kit ?
PostPosted: Tue Dec 10, 2002 11:17 pm
this is for all the lift guys.how hard is it to lift a luv.i'm actually trying to get the one on ebay but not sure about using it.do you have to do anything extra like stearing arms,pitman arms or any thing else like that??also how long would it take to lift??
PostPosted: Wed Dec 11, 2002 8:04 pm
hey didnt you already lift yours 3"(or am i going insane? 8O ).
I dont know about any kits ever being made but if you need to lift it just use the variable hight controll for the front end (should be one 22MM bolt on the 3rd member of each side) and just retention your strut bar after wards. I dont think you have to replace pitman arms or anything untill you start hitting 4" and up lifts, and after that you have to go up to cross over steering so you dont have bad bump steer issues.
Oh and on a side note, the lift kits for IFS isuzu pups do the same thing as i have just described (you can look at em for yourself here http://www.calmini.com )
PostPosted: Thu Dec 12, 2002 12:44 am
i have a 3 inch lift now but i wanna go higher!my torsion bars are up as high as they go.i wanted the body lift but i've changed my mind.as soon as i can get thinner tires for my rims i plan on dropping it again.
PostPosted: Thu Dec 12, 2002 12:55 am
well if you wanna go higher you can relocate the torrsion bars. If you look the ends where you adjust the hight is "keyed" (or has teeth). If you pull the torsion bars you can rest them so that the lowest point on the adjustment arm puts you loer controll arm at 3" of lift. I dont know how intensive this would be but i have looked through my shop maunual and this can be done. Oh and another thing make shure you retention your strut bars to specs befor you off road too much. I have toyotas whith bar lifts break those things.
PostPosted: Thu Dec 12, 2002 12:56 pm
thanks alot man.i'll check into it
PostPosted: Thu Dec 19, 2002 11:38 pm
quick question, do you actually off road at all after the lift.
PostPosted: Fri Dec 20, 2002 12:33 am
i used to do it alot until my girfriend had a baby.the only thing i do now is work :( ,sleep :D ,getting f*cked up :lol: ,and work on the truck :D .i've always liked to get in a little mudd puddle or dirt.
Users browsing this forum: Baidu [Spider] and 28 guests
