It is currently Wed Jun 17, 2026 2:38 am
 Post subject: Progress Pics
PostPosted: Mon Dec 06, 2004 12:26 am
Well, decided to take a break from my electrical woes, and did this upgrade this weekend....
Before:
After:
Seats are from a 1988 Honda Prelude. I think I might redo the mounts I fabbed, but that is something to do later.
This next pic is of my guage cluster I installed after I replaced my engine. Wanted to be able to keep a better eye on things and it fit just perfect. As for a stereo, now that I have my buckets in, I am working on a custom console, we'll see how it goes.
More to come as I get the urge. Was in a sharing mood tonight I guess.
Later gaters,
Chad
PostPosted: Mon Dec 06, 2004 12:30 am
same seats as I have for mine got them for $40 for the pair ,look like new. The mounts where not to hard to make , no new holes to drill. by the way they look great.
PostPosted: Mon Dec 06, 2004 1:02 am
Thanks Cat, think I could talk you into taking pics of how you did your mounts? Mine work, but I'm just not that happy with the way they turned out.
I do like the seats though and am very pleased with the upgrade.
PostPosted: Mon Dec 06, 2004 1:13 am
ill take some pics tomarrow night when I get home , they are out right now . Im working on the luv so I have orig. buckets in it that i dont care if they get dirty or not
PostPosted: Mon Dec 06, 2004 10:34 pm
These are the mounts I made, didnt make one for the front inerside of each seat. this would be looking down on the driver seat as if the door was open
side view, this mounts to the stock bench seat spots then follows the curve down to mount the seat, the other bolts into the body mount
What it would look like in the truck this is the driver side, all but the uprights are hiden under the carpet
square tube to make the seat level, bolts into seat belt anchor with longer bolt
PostPosted: Mon Dec 06, 2004 11:50 pm
Thanks cat, looks great. I'll take pics of my mounts, it is fairly similar. Just need to talk my buddy with a welder into tacking the bolt heads so it doesn't take 2 people to tighten them down.
Chad
PostPosted: Tue Dec 07, 2004 12:39 am
not a problem, yea the iner bolts are a little hard if you try it yourself
PostPosted: Tue Dec 07, 2004 8:30 pm
Chad......lookin good dude :!: :D
I see that my green paint is still holding up quite well......hee hee hee
PostPosted: Wed Dec 08, 2004 12:11 am
Thanks D, and yeah the green paint will probably be the last thing removed.
Chad
