It is currently Fri Jun 19, 2026 3:11 am
 Post subject: drag shocks
PostPosted: Thu Sep 23, 2004 8:04 pm
im really getting into these v8 luvs and hoping to get one and fix it up myself.mean while i was wondering like on the front of a luv.say you keep the stock front...what type shocks you run l;ike drag shocks can you put coil overs on em and will a shock like camaro/vega work thanks guys
PostPosted: Fri Sep 24, 2004 3:46 pm
Japanese Redneck
I am going to coil overs soon but I currently use Comp Engineering 3 way adjustable (set at 90/10) shocks from a 62-67 Nova. I put a shock extender on it because its a tad too short but it does the job. at the strip i crank the torsions all the way down so the front is sitting on the rubber stoppers. that way there is no resistance from the torsion bar when the front suspension needs to travel/extend.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
