It is currently Sat Jun 13, 2026 9:46 am
 Post subject: sanding Q
PostPosted: Tue Jun 08, 2004 10:06 pm
used to live at Luvtruck.com
well now that I'm home from school, my goal for the weekend-next week is: sand and primer the luv.
But first I need to know...what grit sandpaper should I use to sand my luv?
thanks! pics coming soon once I hook up my computer!
I got my LUV!!!!!!!
PostPosted: Tue Jun 08, 2004 10:30 pm
Jess, You should be able to buy a sand-paper pack, that will have a assortment of diffrent grit paper in it. Then you can kinda experiment, til you find one that will do what you want. If I remember, the blue paint wasn't real thick, so I wouldnt think that a reall heavy grit would be needed. Hope that helps. Don't forget the pics :D
PostPosted: Thu Jun 10, 2004 7:48 pm
Depends on what you want to do? Are you wanting to remove the paint or just cover the dull paint? If your just wanting to cover it up. I would sand it with 180 or 220 grit. Any thing more course than that and the primer wont fill the sand marks...hope this helps
Kevin
