It is currently Thu May 14, 2026 4:09 am
 Post subject: Need Taillights
PostPosted: Fri Apr 02, 2004 7:36 am
I need taillights for a 76. Anyone know where I can get em? The ones I have the sockets are all rusted out.
I could get new sockets if I knew where to get them!!!
PostPosted: Fri Apr 02, 2004 10:11 am
the sockets should available at any parts house
PostPosted: Fri Apr 02, 2004 10:50 am
Thats true. Ive done that before. Had to use universal type sockets, but they work.
PostPosted: Fri Apr 02, 2004 11:38 am
Advance did not have them, neither did Autozone. I am going to go see if PepBoys has them next. I need just the backup sockets.
In a related note. The backup lights don't work. I have looked at the wiring and it's all there. I guess I will have to come up with an alternate fix to it and bypass the harness like I had to with the ignition.
PostPosted: Fri Apr 09, 2004 9:05 pm
If '76 has the same tail ilghts as '77 I have a set in the bed I pulled off mine. If you wasnt them you can have them just pay shipping. But let me know quick. Because the 72 is going away real soon.
PostPosted: Sat Apr 10, 2004 11:46 pm
You might check your backup light switch on tranny had the same kind of problem come to find out my switch was bad....
PostPosted: Sun Apr 11, 2004 10:35 am
I bought new sockets and put them in. Now all the lights work and they are not all rusted.
The backup lights work now after replacing the switch. Now I have to make sure that the switch is screwed in all the way cause the lights stay on.
:roll:
PostPosted: Mon Apr 12, 2004 6:55 am
These switches must have a common problem cause have had that problem too and yet had to buy another switch cause it got stuck engaged..... :roll:
PostPosted: Mon Apr 12, 2004 7:54 am
I wonder if a little bit of silicon grease will help it a bit.
PostPosted: Mon Apr 12, 2004 11:44 am
Let me know if it works cause will put some on the new switch I have now to prevent from having to get another...
